on 08-08-2022 10:48 AM
I’ve activated roam further before leaving the UK but didn’t realise I had to enable roaming through my account settings. Now I’m in the USA and can’t turn it on through my account. It keeps saying there is a problem. How can I fix this?
on 08-08-2022 12:48 PM
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
