Can’t call Luxembourg numbers whilst in Luxembourg…
richardunderhil
EE,
I’ve been having an issue calling Luxembourg (+362) numbers from my mobile. They can call me but I can’t call out! Why would that be and how can I fix it?
Rich
@richardunderhil : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
