Calls
Jks2006
We are in India, I have a call plan added on, but do I leave data on or off to make and receive calls to the U.K.?
Also, there is no signal on my iPhone to show I’m connected to a network provider over here.
any help is appreciated
@Jks2006 : You don't need data to make calls or texts, but it ain't working anyway.
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you have no coverage displayed on your phone, that's the underlying problem - and will stop you using anything that needs a mobile network, which means calls, texts & mobile data.
As per the reply above, are you on pay-monthly or PAYG? The advice for resolving this depends on the answer.
