Calls when abroad
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
13-02-2023 08:00 PM
I am in St Vincent. My data roaming is on. EE have confirmed I have worldwide roaming. I am connected to Digicel the local Caribbean network. I can call UK numbers. When I call a local (St Vincent) number I get "call ended" with no ringtone. Note that the local number, in the format I dialled is operational - my wife can contact it on her phone (also on Digicel). Using 150 I get "cannot connect the number dialed". Cannot find a way to talk to a human at EE.
Help please all guidance greatfully recieved. Thanks
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
13-02-2023 08:25 PM
@BazzaS Try calling +44 7953 966 250 this is a chargeable call mind you.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
13-02-2023 09:45 PM
@BazzaS : Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-02-2023 12:11 PM
Thank you ChrisB & Xray,
Unfortunately the EE phone numbers you have suggested all result in the same sequence: an email, a virtual chatbot, the option to call. This latter presents 150. Which when I dial it returns "cannot connect using the number dialled".
So I am no further forward still being unable to make local calls and unable to contact 150 and thus no human interaction.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-02-2023 12:44 PM
Are you able to manually connect to Flow SVG?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-02-2023 02:03 PM
Have just connected to FLOW and for good measure restarted my phone.
150 now connects and rings.
But still cannot ring local numbers - get 'call ended' with no ringtone.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-02-2023 02:44 PM
Hi @BazzaS
Thanks for trying this.
Please call us on 150 if the call now connects, and the team will get this looked into for you.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-02-2023 03:07 PM
Called 150 got chatbot, option 'roaming', option 'call us' presents 150
(again!), dial 150 get "there's been a problem with your request",
presented with option 'call us'
In other words going round in circles.
Very unimpressed with EE at the moment - will probably revert to Vodaphone
when back in UK.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-02-2023 03:38 PM
Hi @BazzaS
If you select option 2 and the technical support this will get you to the correct team to get this looked into.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
15-02-2023 04:08 PM
I used option 2 as advised and after identity checks a lady texted me a 6
digit pin. When I tap the pin I'm prompted to "call". When I call I get
"this number is not recognised".
How/where do I use this pin?
