on 12-08-2020 03:55 PM
I've recently migrated across to EE from another provider.
I'm using a Samsung Android phone.
I've noticed that when I receive calls from other uk-based mobile numbers they show up as international calls.
Has anyone else experienced this and do you know what causes it?
on 03-12-2021 09:08 PM
I contacted Samsung and they had never seen issue before. However they backed up my messages, then deleted and restored and all now working correctly
on 16-12-2021 11:28 AM
I tried that, but doesn't seem to have worked. I still see the Spanish flag on all messages from contacts not in my contacts...
on 16-12-2021 11:58 AM
Hi @gavb1,
Welcome back to the EE Community. 🙂
Our Tech Gurus will be happy to look into this issue if you get in touch with Customer Care.
09-07-2023 05:11 PM - edited 09-07-2023 05:16 PM
Bumping this thread as I've just spent the day trying to resolve a similar issue and think I've identified the (or a related) problem.
EE don't send UK callerid to customers in the standard +441234567890 format (as Vodafone and most international networks do) but instead as the local UK format (i.e. 01234567890). This means when you store the number as a contact, the phone doesn't know which country it's from (and when roaming it may also not work). Now in the UK this is not usually an issue if you don't ever travel abroad. However if you do, you may find that either contacts don't work when you get there, or if they do (because the phone is trying to guess the country) when you get back they stop working or are shown as being in the wrong country.
The solution is to store all your contacts in the mobile standard +441234567890 format. Unfortunately on EE, since the callerid is sent misformated without the +44 in the first place, if you store a number when someone calls you (as just about everyone does) you'll have to manually edit every contact to add +44 and remove the 0. This is an EE issue.
