Calls not working internationally
Clrichardson83
Hi
I’m currently in New Zealand and have added the roam further package onto my monthly plan which means I should be able to use all my calls, data and texts as if I was in the UK but for some reason I can’t make any calls at all - not even to 150 for help. It just comes up with call failed.
can anyone help?
@Clrichardson83  did you enable roaming on your EE account? Purchasing add ons doesn’t enable roaming it’s just an add-on so you can use your allowances or keep the cost down when you’re abroad..    you’ll need to contact customer service to have roaming enable on your account.   You can use live chat via your EE account to contact customer services but you’ll have to wait till an agent is free to chat.  You should get a pop up asking you if you like to live chat.   Alternatively you will have to call customer services from a different device on +44 7953 966 250
To add - check whether your phone has signal indicators of a NZ mobile network - if it doesn't, that is the root of your problem as mentioned above.
If you have coverage of a Kiwi-network, then there may be an issue with that network - often manually selecting an alternate network and/or restarting your phone, can resolve that.
dexterkrol
I am in New Zealand at present and have exactly the same problem.  I understood the EE roaming package covered New Zealand but my iPhone is not connecting to any local service provider and I cannot connect with 150 EE support
Hi @dexterkrol
The post above from chris_b answers your questions.
Katie_J
Good morning @dexterkrol.
Welcome to the community.
Did you enable roaming before leaving the UK?
This could have been done by texting ROAMING to 150 or by giving us call?
Have you tried manually connecting to another available network?
Katie
