Calls not working in Australia
Weebobby
Hi I am currently in Australia and I paid EE the £10 Add on before we left unfortunately I can’t make or receive any calls has anyone got any advice I’ve also turned roaming on
Julz60
I’ve got exactly the same problem. I spoke to EE in the UK last night and I’m now showing as being on Vodafone  AU network but still can’t call or text. I’m going to a phone shop here today to see if they can help me. Good luck, I hope you get sorted.
@Weebobby : As  you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
