on 14-10-2023 01:23 PM
In Malta
Have EE connection
Can't send texts. Error 10 when attempting to send.
Have paid to have data, texts and minutes in Europe.
Any help appreciated
on 14-10-2023 01:33 PM
Can you make calls & use data?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c.
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
on 14-10-2023 07:05 PM
@GHB1 wrote:
In Malta
Have EE connection
If you are in Malta, you are roaming and your phone will be needing to connect to a Maltese network, not EE-UK. Any billing addon is immaterial, what matters is that you enabled international roaming before leaving the UK - normally by texting ROAMING to 150. Did you do this?
If you did not, then your phone will not have permission to connect to foreign networks. Does it show a connection to any Maltese networks?
