18-12-2022 12:11 PM
call waiting does not work ive activated it through the setting and still doesn't work
18-12-2022 03:06 PM
18-12-2022 03:16 PM
Are you on PAYG or pay-monthly contract?
The facility is only available on pay-monthly.
13-04-2023 06:39 PM
My call waiting doesn't work.
I have checked the setting and it is showing as switched on.
My phone is a Samsung s22 ultra.
Help would be appreciated.
14-04-2023 07:52 AM
Hi @Cazzie70
If you speak to our Mobile Care team, they'll be able to check if everything is set up from our side.
15-06-2023 07:13 PM
I have this exact problem on my S22+... I've previously spoken with the EE call centre and technical team and they assure me everything is setup at their end. The call waiting setting is enabled in the settings menu and *#43# confirms call waiting is activated and *43# says call waiting is enabled. This problem has only started since I changed my phone and plan last October/November and it's causing me to miss calls.
Please can you help?
16-06-2023 07:49 AM
Hi @Jazzy71
I'd recommend continuing to speak to our technical support team so they can look into this further.
30-05-2024 09:16 PM
I'm having same issue did you manage to get this sorted
31-05-2024 08:04 AM
Hi @Kiimmiie26.
Welcome to the EE Community.
If you have not yet already, I'd recommend checking your account is set up correctly with our customer care team.
The team can be reached by calling 150.
Katie
10-02-2025 02:49 AM
Iphone16 but previous phone galaxy fold 5 didn’t work either
