Community Activity
Payroll & HR contact
Can anyone help me please with contact details for payroll or HR?I'm an EE staff member (long term sick), I haven't received any payslips since I don't know when & I also need to speak to HR.
Issues with slow connection
Hello,I am having issues with my EE broadband connection, have had the router replaced by EE and have had the white modem box on the wall replaced but is has not fixed the issue, I have my TV connected by cable straight from the router into my TV but...
Resolved! Roaming to 150
so -if I type ROAMING to 150 (or in fact if I type ROAM or RO Jersey) as guided on the website I just get the options of GOING, ABROAD,BACK HOME  none of these options actually shows the rates it says I should see and nothing tells me anything is ena...
P-JC by Investigator
  • 68 Views
  • 7 replies
  • 4 Helpful
Extending ringing time on Nokia 105/ non smart phone
Hi, I want to extend ringing time of my Nokia 105. It only rings twice and cut off. As my phone is not a smart phone… those number came up on Google search did not work. Is there any different way? I tried to make my voice mail back on but it is not ...
Achan1 by Contributor
  • 13 Views
  • 2 replies
  • 0 Helpful
Rubbish broadband
Anybody else had issues with broadband after switching from BT to EE. I was with BT for years no issues. In the last 2 months I’ve spent more time on the phone to EE than working so frustrating. Any advice how to get out of this nightmare would be gr...
Ronbles by Explorer
  • 168 Views
  • 7 replies
  • 2 Helpful
Issues with phone ringing
Hello,I am having lots of issues with the EE Digital Home phone, when the phone rings Try to answer the call but as soon as I do the phone ends the call and going straight to voicemail. Have had the phone replaced by EE and the Router replaced, the a...
Terrible broadband
Moved from BT to EE was told it would be better because we would have a direct line, but honestly it’s much worse. Signal around the house is terrible. Everything is fuzzy and takes ages to load. Extremely disappointed
Ian233 by Visitor
  • 512 Views
  • 6 replies
  • 2 Helpful
Microsoft Teams Quality Issue
Hello all,I've got an odd issue which I'm hoping someone can offer a steer on.I have the EE 1.6 Gb Full Fibre Busiest Home package with a Smart Hub Plus.All seemed to be working fine until my original Smart Hub Plus failed in Jan 2025. This was attri...
