24-02-2026 10:04 AM - last edited on 24-02-2026 10:08 AM by Leanne_T
I've read in many places about dialling the following code:
**61*+447953222222**30#
Doesn't work for me. Instead it enables call forwarding, which I don't want.
And if I dial *#61*11# to get the current ring time, it doesn't show the ring time, it shows the call forwarding status.
Has EE changed these codes?
[mod edit: added title]
24-02-2026 11:45 AM
These codes are not EE-specific but international industry standard.
The code you've quoted contains some errors, you've not said but I presume you're wanting to alter the length of time an incoming call rings before diverting to voicemail. If so, the correct code is *61*[dest]*11*[sec]# where [dest] is the destination number & [sec] is the delay time in seconds.
EE have implemented a delay of 5second intervals between 5-25 (IIRC, it may be 20 now) and the voicemail number you need is 07953222222
24-02-2026 11:45 AM
26-03-2026 02:52 PM
Tried all the permutations but never changes the value from 20secs for all call forwarding services.
Having sent the change request I get a confirmation of MMI code accepted but time remains at 20 secs.
My VM number is 22258. I have tried using that in the above command as well as 222222, with and without the 7953 in euro form or UK form but no changes.
