18-08-2022 08:27 AM
20-08-2022 04:06 PM
@frankcassidy : When in the RoI you are roaming. To be able to use EE services while there you need to have roaming enabled on your a/c.
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
18-08-2022 08:37 AM
From where to where?
18-08-2022 08:46 AM
Welcome to the community.
Is it all calls that are barred? Even to UK mobiles and landlines?
20-08-2022 03:58 PM
Yes all calls to UK mobiles and landlines are barred. I'm on holiday in Ireland but my EE mobile has never barred calls previously. Thanks
20-08-2022 04:06 PM
