Barred from making calls from Portugal
Digbydog1
I cannot make calls from Portugal to U.K.
I registered my intent with EE two days before departing and was told that my contract was over two years old and calls &texts would be free.
Now automated voice tells me-
“ All international calls are barred- including to EE”
Can anyone advise
Thank you
Don
@Digbydog1 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
