I'm in Cyprus and cannot make calls back to the UK - message says calls barred
Steverob2653
If you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
Katie_J
Good morning @Steverob2653.
Thanks for coming here.
Did you receive a welcome text when you landed in Cyprus?
Did you activate roaming before leaving the UK?
Katie
