on 18-08-2022 09:04 AM
I am trying to make a phone call from Barbados, it was working a few days ago but know telling me this phone is bared. Would contact ee but the only way is to phone them (great solution for help we!) any help appreciated.
18-08-2022 11:11 AM - edited 18-08-2022 11:12 AM
Hi @Gordon44
Welcome to the community.
Could you try connecting manually to a different available network please? Do you have a pay monthly or pay as you go SIM card?
on 18-08-2022 11:38 AM
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
on 18-08-2022 09:01 PM
Thank you. Manually selecting a different network worked. I am on a contract, did the data roaming before I left but as I mentioned I had it working and making calls from a different network while I was out here. It does seem a lot more difficult to use the phone while abroad from what I recall a few years ago. Is it me or is this an EE problem?
on 18-08-2022 09:08 PM
