on 06-06-2022 06:54 PM
My daughter is off backpacking in Europe for 33 days, which would be the best option for her to use her phone abroad?
Solved! Go to Solution.
on 06-06-2022 08:24 PM
You may use your usual UK allowances there with up to 50 GB (contract) or 25 GB (PAYG) data per billing month if you have more. If on contract & your contract started after 07/07/2021 there'll be a £2 / day charge for using your UK allowances in EU or you may buy the Roam Abroad Pass for £10 / month.
If you are on contract, remember to text ROAMING to 150 before you leave UK to check roaming is enabled on your account.
on 06-06-2022 07:26 PM
Is your daughter on PAYG or pay-monthly?
on 06-06-2022 08:38 PM
