24-08-2022 08:12 AM
Hi, can anyone tell me which device I should use for booster the wifi signal when I am driving in motorway. And I found the mobile wifi switch off itself automatically, how can I fix it?
24-08-2022 01:17 PM
Hi @Kaikong
Thanks for coming here.
Does the WiFi connection disconnect when the WiFi device goes off?
Which device are you using?
Thanks.
24-08-2022 05:10 PM
What device(s) are you using?
WiFi is just a connection between your mobile device and a router.
Unless you're connecting a phone to a mobile router, then I'd suspect you just need to use mobile data while travelling on a motorway.
25-08-2022 09:40 AM
I’m using 4GEE WiFi Mini
25-08-2022 09:42 AM
I just don’t want to use my mobile data when I’m on the journey and that’s why I use the mobile wifi
25-08-2022 09:46 AM
Hi @Kaikong,
Your mobile WiFi router will automatically switch off when not in use to conserve battery life.
Do you see the same issue if it is plugged in to a power source?
25-08-2022 11:54 AM
It doesn’t has this issue if it is plugged into a power source. But the signal is very weak on motorway and can’t be connected well. That’s why I’m thinking to find some ways to boost up the WiFi signal receiving
25-08-2022 12:00 PM
Hi @Kaikong,
Sorry, it isn't possible to boost the strength of the mobile signal your router is receiving in a particular area.
