18-10-2025 02:30 AM
I've just paid for 24 hour access to my data allowance while I'm in Mexico. My phone can access the EE Add On page via the provider TELCEL and 4G is showing as available. However, when I use my browser or any apps there is no internet connection. Any advice would be appreciated.
18-10-2025 04:44 AM - edited 18-10-2025 04:44 AM
@dave517 : Can you make calls & texts?
Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before leaving to go abroad?
If you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
