25-06-2021 09:30 AM
I brought my sim card from London to Italy, I put it on my cell phone but it doesn't make calls, I use mobile data and doesn't receive either. How active is he outside of Uk?
25-06-2021 10:12 AM
Hi @Marcela1982
You need to activate your SIM on the UK EE network. EE Sims are designed to be used on the UK network. Your SIM cannot be activated abroad.
25-06-2021 10:12 AM
Hi @Marcela1982
25-06-2021 10:17 AM
Thanks. I carried a 20 pound roaming package for 30 days, can I reverse this amount?
25-06-2021 10:30 AM
Hi @Marcela1982,
Where did you purchase your SIM? You'd need to contact to the retailer to request a refund.
25-06-2021 10:34 AM
My SIM my brother bought it in the UK and sent it to Italy, I uploaded it in the Ee app.
25-06-2021 10:37 AM
Hi @Marcela1982,
If your brother purchased the SIM direct from EE, he should contact Customer Care to see if it is possible to receive a refund. If not, he should contact the retailer he purchased it from.
