Abroad
Hamed021
I am in turkey and my data doesn’t work .?!
@Hamed021 : Can you make calls & texts?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
