Abroad with no network!
Charl1414
Hi!
I am currently abroad and have no service! I have a spend cap so thinking maybe this is why! I can’t contact EE direct as I don’t have a network to text or call! I need my network working as I can’t log into my online banking etc without code’s getting sent to my phone first!
can anybody please help? Thank you! X
@Charl1414  Did you enable roaming on your EE account by texting ROAMING to 150 or did you call customer services to request this ?   The spend cap has nothing to do with the ability to connect to a roaming network.   Ie the no service issue you have.
Charl1414
Hey no I didn’t but there’s no option to do that now I’m here as I have no service? I really need it for work and admin / money stuff! X
Thank you! I will try that!
