Abroad call
Hana88
I have purchased an add on, the 30 minutes from abroad. I am trying to call but i am being told that calls have been barred for this number. I am in Bahrain trying to call a UK number.
@Hana88 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
Northerner
Hi @Hana88
You need to activate international calls and text via your online account or EE app.
