150 text problem
ajfclsjc
Did you get this issue sorted out in the end as texting 150 gives me no replies or anything at all
Rach_H
I'd recommend reaching out to our team @ajfclsjc, and they will be able to take a look into what is happening with your messages, and help you get this sorted.
Rach
17 REPLIES 17
The post you'd added to was quite an old one.
Can you explain more details on the issue you have with the 150 text service?
@ajfclsjc : Are you on contract or PAYG?
SS added showing I get no replies from it. On SIM only contract
ajfclsjc
I'm on sim only contractor. Not sure for how long had contract but by end of January I'll be allowed early upgrade and get a device and SIM
Peter_W
Welcome to the Community @ajfclsjc.
We've split your post into a separate thread so we can make sure the replies you get are all relevant to the issue you're experiencing 😊
Is it just texts to the 150 service that appear to not be working here, or are you struggling to send to other numbers as well?
It's worth trying to send a text to your own number and see if this comes back.
Peter
Originally was just 150 texts but now it's all SMS messages are not delivering. Including trying to SMS myself, RCS messages are unaffected
Are you in UK?
Can you make calls?
Yes I'm in UK and everything else seems to work fine can make phone calls and use mobile data tried looking for SIM settings but can't find it anywhere so can't check my message centre number.
Using a Xiaomi Redmi Note 14 4g phone
