sim card without service
vitiok70
Hello, who can help me? In iPhone 13 today I activated sim in esim. After in the settings, I accidentally removed the physical sim, and the esim was automatically removed as well. I tried to activate esim again, but since the physical sim is out of service, I cannot receive the pin code via sms to activate the sim. How to reactivate the physical sim card? Thanks
15 REPLIES 15
Jon_K
Former EE Employee
Hi @vitiok70.
Sorry, I thought you said the store had registered a physical SIM card for you, not an eSIM.
Do you have both a physical SIM and an eSIM registered?
You can keep the QR code for when you need it, it doesn't need to be registered straight away.
Jon
in the store they replaced my physical sim, in the evening coming home in the MY EE application I activated esim, then I removed the physical sim from the phone and replaced it with another physical sim from another operator. But a few days ago I already requested the esim QR code and of course I received it. Now I want to know, in the future I can use the QR code to activate esim, is it multi-use? because anything can happen with the phone, digital errors etc.....
Jon_K
Former EE Employee
I'm going to find this out and get back to you as soon as I have an answer, @vitiok70.
Thanks for your patience with this.
Jon
Jon_K
Former EE Employee
Hi @vitiok70.
The QR code from a store is single use.
You can however get a replacement in the My EE App if you need one.
Jon
Thank you for the answers. Ok, but what do I do in case, if something happens with the device or something careless happens and I suspect that the eSim registration is lost. Do you think it is possible to replace the eSim in My EE? how do I receive sms with the eSim replacement pin, if the physical SIM is already deactivated?
Jon_K
Former EE Employee
Yes, you can replace it in My EE, @vitiok70.
You'd be able to do this in the app, you'd need to log in using your details on a new phone if something were to happen with your current one.
Jon
