12-05-2024 04:54 PM
my phone has had no service since yesterday meaning my data isn’t working and i cannot make any phone calls. i have removed my sim card multiple times and restarted my phone multiple times too.
12-05-2024 07:37 PM
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker in the first instance, to check for local service outages. A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
