‎02-03-2026 03:13 PM
‎02-03-2026 03:42 PM
Does your phone show coverage indicators? Can you send & receive text messages? Are you in the UK or abroad? When were you last able to make or receive calls?
‎02-03-2026 05:33 PM
‎02-03-2026 05:38 PM
@ianssmith You’ve tried to put your question in the title header. Click the reply button and then type your question.
‎02-03-2026 05:56 PM
@Chris_B wrote:@ianssmith You’ve tried to put your question in the title header. Click the reply button and then type your question.
Not just that, they've also started two separate posts which I've now combined.
The same point applies though - ianssmith please respond by means of reply, there's no need to start another new post.
‎05-03-2026 01:26 PM
im rapidly losing patience with ee.im having issues with not being able to make or receive calls except on whatsapp or messenger.trying to get through to them is an absolute nightmare via 150 .they call me back and cant get through.i spent over an hour yesterday trying and again today.im told that if they enable wifi calling the issue would be resolved .can someone tell them
‎05-03-2026 01:45 PM - edited ‎05-03-2026 01:46 PM
@ianssmith is this issue indoors or outside ? if indoors does your device show that it’s connected to the EE network ? You enable WiFi calling on your device as it’s a device setting, what device is it?
‎05-03-2026 02:36 PM
@ianssmith wrote:im rapidly losing patience with ee.im having issues with not being able to make or receive calls except on whatsapp or messenger.
You have an existing thread where other users have tried to help you, but you've started yet another new post. The questions that were asked of you in a previous post were... "Does your phone show coverage indicators? Can you send & receive text messages? Are you in the UK or abroad? When were you last able to make or receive calls?"
You've now mentioned using internet-based apps, are you using those over WiFi or the mobile network? I ask because if you're using them over the mobile network, that's an answer to whether your phone shows coverage indicators.
WiFi-calling is usually enabled by default.
‎05-03-2026 06:04 PM
‎05-03-2026 10:55 PM
What advice did EE-CS offer you, and how were things left?
Additional questions were asked of you in a previous post were... "Does your phone show coverage indicators? Can you send & receive text messages? Are you in the UK or abroad? When were you last able to make or receive calls?"
You've also mentioned using internet-based apps, are you using those over WiFi or the mobile network? I ask because if you're using them over the mobile network, that's an answer to whether your phone shows coverage indicators.
