interference for overlapping cell with frequency
shaun3becketal6
www.cellmapper.net shows two EE base stations using the same frequencies and cell configuration fully overlapping my house (Cells 5785089 and 4136449) - I get strong signal, but lots of noise - it is rural so I can see both transmitters. How do I get conformation from EE this data is correct and a solution to separate the signals. I have external router with omnidirectional antenna. forcing 4G helps but I can't limit the eUtran band as apparently, they both use the same frequency DCS (B3 FDD) 1846.7MHz.
Can you explain what you mean by "lots of noise"?
EE's 4G network uses multiple frequency bands, but B3 is the base layer and doesn't need separating in the way I suspect you believe.
Can you explain the issues you're facing, the problem is likely to be elsewhere.
