cant make any calls inside the house
Kasia84
All this week i cannot make any calls from inside the house and EE is less than helpful. I am not set for wifi calling, i have restarted my device etc, etc.
I flagged it to EE on the online form , they said they could not find any  issues with their network in the area and to CALL them on 150 if i still experience problems. Guess what EE, I cannot call you!  because your network is not connecting any outgoing calls!  What the heck is going on with you ?
@Kasia84   Why don’t you use Wi-Fi calling?     What do you mean you’re not setup for it ?  You just enable this on your phone.     Just to point out no networks will guarantee a signal indoors as buildings can block signals.  Do you get a signal outdoors?
The only setup needed for WiFi-calling is to enable it in your phone's menu system.
You can contact EE CS from any working phone using 0800 0798586.
