24-10-2023 06:00 PM
is anyone one elese having issues with calls just going straight to voice mail and not ringing ? had it all day sat and again today when i check network status says everything is fine ?
24-10-2023 06:05 PM - edited 24-10-2023 06:06 PM
Hi @Heather1984
Are you using the EE network or wifi calling.
Have you tried restarting your device.
24-10-2023 06:29 PM
24-10-2023 06:31 PM
hi using ee network have wifi calling off my daughter can call everyone elese seems to go straight tp voice mail did this sat and then fine till today iv restarted and taken out my sim
24-10-2023 06:49 PM
If only particular numbers are affected, this often suggests call blocking. Is there a reason you've turned WiFi-calling off?
If you test-call your own number, does the call connect as you'd expect?
