Zero signal RH19
NJP2103
For the past 48 hours my device has not been able to connect to the mobile network. The coverage checker says no issues in RH19. I have tried the airplane mode switch and device restart but no fix.  Anybody else experiencing similar issues or may have a solution?
Does EE show on a manual network search?
If yes - try connecting manually, that will ID whether your issue is account/SIM-specific if you can't do so.
If no - you have clear evidence of a local coverage outage. Use the "report a problem" link on the status tool.
Thanks. Things seem to be back to normal so not sure what the issue was.
Peter_W
Thanks for the update here @NJP2103, I'm glad that you've noticed things improve again.
If you'd like to take a closer look into what exactly happened here, and check to see if there's anything available in the way of compensation, please give our technical team a shout and they can help get this sorted.
You take care.
Peter
