Wifi Coverage Boost and BT-Wifi
samuelhau
Hi How are you doing
As a BT broadband user, I have the BT-Wifi app that helps me to join the BT-Wifi network. Now I joined a EE plan, it has a feature called Wi-fi coverage boost (which in addition has cover for London Underground?)
According to the documentations I found, it appears that with an iPhone I don't need to do anything (except leave wi-fi on) and the phone should automatically connect to EE Wi-fi, which is supposed to be the same (or better?) than BT Wifi.
So in this case, should I be deleting the BT Wifi app and forget about the BT network to lesson the complication of the phone finding which wifi to join and with one less app running in the background?
Northerner
Hi @samuelhau
From my experience on the London underground you need to manually select the network, then it auto logs in.
That is a great tips.
But I should use EE Wifi, and not use the BT-Wifi app is that your experience?
