24-03-2024 01:12 AM
My signal is terrible and will drop out multiple times over a short period. This seems not just to be confined to my address but locally too! I don’t have Wi-Fi at home so can’t use this.
I lose calls, can’t make calls sometimes. I know it’s not the phone as I swooped it out. I’ve reset phone and still no joy.
A while back I went in to the Ee shop in town and was told that during COVID the masts went down and have yet to be repaired
this is unacceptable, if true.
I also tried multiple times to send complaint via app but kept losing signal Anyone else have this?
24-03-2024 09:09 AM
Hi @S1monJohn
I'm sorry to hear that you're having problems with your service, do we have any known problems or maintenance showing for your area on the EE Coverage & Network Status Checker if you enter your postcode and select 'check status'?
Thanks.
24-03-2024 06:42 PM
You can safely conclude the Covid explanation is at best "inventive".
Is this a recent problem, or a long-term one? Coverage issues are inevitable with all networks, none have complete blanket coverage and all have poor areas. Does the coverage you get, broadly match that predicted by the "check coverage" option on https://coverage.ee.co.uk/coverage/ee ?
Or are you having problems with call & mobile data performance when your phone shows good coverage? The advice differs between the two scenarios.
24-07-2024 10:29 AM
I have similar issue, can make calls, but can't connect to the internet, this is not only in St Albans area, but also in certain parts of London. After calling the technical support, the internet connectivity improved but only for 2 days. The EE shop advisor in St Albans confirmed that there is an issue with signal in our area, but EE denying it.
I was moved from Plusnet to EE. Is it the cause?
24-07-2024 12:47 PM
Hi there @AndreStAlbans
I am sorry to hear you are experiencing signal issues.
You can report any service issues on our Service Status Checker, and the network team will get this looked into and keep you updated either by email or text.
If you would like to get this looked into in more detail, please call us on 150 and our tech guides will help you further.
