Signal
Emma424
Hi can please help me as I haven't had signal for the past month and I have paid my bill and I can't make calls or Receive calls aswell I have e taken the sim out and put it back in plus I have done Airplane mode turning it off then back on and still nothing
Northerner
Hi @Emma424
  • What device do you have and did you get it from EE.
  • Have you tried the SIM in another device.
  • Are you in the UK.
  • Does this issue only happen in one location (home,work etc)
  • Can you use WiFi calling.
I have got a Samsung galaxy S23 ultra and I got it from EE I have done everything I can think of and I'm from the uk
Are you only having this "no coverage" problem in one specific location, or is it non-area-specific and it happens everywhere?
The former could potentially be a protracted coverage issue, but the latter would suggest a device/SIM problem.
Do other EE users have similar problems in the same location you do?
