Signal in Slough
Cheryle
Every EE user seems to have issues with the network when reaching the Slough area (SL2 postcode). this has been going on since Wednesday. Is there an issue and is it being worked on?
1 ACCEPTED SOLUTION
Jon_K
Former EE Employee
Hi @Cheryle.
Welcome to the community.
You can check your postcode in our Network Coverage and Status Checker to see if there is any ongoing work.
If there is no work ongoing, you can report a problem using the checker too.
Jon
Jon_K
Former EE Employee
Hi @Cheryle.
Jon
