Signal Issue TW20
KH200
Is anyone else experiencing lack of signal in the TW20 area?  The coverage checker says indoor and outdoor signal on 4G should be good.  Has there been a change as I have gone from good signal to no signal over the past week.
6 REPLIES 6
It sounds like you've used the "check coverage" tab on the status website. Try using "check status" instead - this also has fault reporting functionality.
Many thanks for the help.
I have checked the status and there is a problem in the area.
Jadesharp1992
 the tw2 area and signal is dreadful! I have reported, reported, reported and they will not even look into it. The coverage checker says the service on 4g should be exelent indoors and out, and i'm only geting 1 or 2 bars and speeds are like they are on dialup! There are no known problems in the area.
Katie_J
Hi @Jadesharp1992
Did you speak with our technical care team or has this been reported on the coverage checker?
Katie
Jadesharp1992
ave spoken to the top level tech team and reported it on the checker. Top level tech have looked into it and they said it's the line of sight of the mast that I have here, apparently there's lots of obstructions in the way so the mast isn't getting the best signal here. they don't know if/when 5g will be added or if/when a nearer mast will be built, so basically, I have been told there is nothing they can do here.
Leanne_T
I am sorry to hear this @Jadesharp1992
If you would like to discuss your options please get back in touch with our technical support team who will be happy to help.
