Service checker is down
hattie057
The service check website is down and when I tried to call ee for technical support it told me it was closed. My data has been down for two days now and I can’t get onto the internet. It’s shocking because we are paying for data we can’t even use, and being in a more rural area it’s a lifeline for connection.
Debbie_G
Hi @hattie057.
Welcome to the community.
I'm sorry you've been experiencing issues with your data connection.
Are you able to access the Service status checker today to check for local outages?
Could you also try manually selecting the network? Go to your phone settings, choose Mobile Network, turn off Automatic, and then reselect EE. This can refresh your connection to the local mast.
If you're still having trouble, I'd recommend getting in touch with our technical team, who will be able to take a closer look and help get this sorted for you.
Debbie
@hattie057  Customer support is open till 9pm.
Just to check are you or was you in this location when you posted this comment
Data usage doesn’t affect calls/texts so can you call or text in this location?
Debbie_G
Hi @hattie057.
Debbie
@Debbie_G  It’s still not working
@Debbie_G  And via the web browser I get
ee_user14
Skilled Contributor
Skilled Contributor
Status checker is working fine for me, via web & mobile app.
