05-03-2024 09:48 AM
Same issue since yesterday evening. Was working again for a period this morning before going back down again. I'm in Motherwell, near Glasgow.
05-03-2024 09:51 AM
Morning @Jon83
Do we have any maintenance or problems reported if you enter your postcode and select 'check status' on the EE Coverage & Network Status Checker?
05-03-2024 10:03 AM
Hi Leanne,
According to the link, there is good coverage in my area. However, the link below suggests there are problems for others too.
Thanks,
Jon
05-03-2024 10:07 AM
Hi @Jon83
If you select 'check status' on the coverage checker, this will show any reported problems and you can register for updates once we have further information.
05-03-2024 10:11 AM
It stills says no issues. I've reported the problem, however hard to imagine this isn't part of a wider problem, at least in this part of Scotland.
05-03-2024 10:15 AM
Just as an update - my connectivity has returned, for now at least
05-03-2024 10:24 AM
Thanks for reporting this and letting me know @Jon83
The report will be looked into by our network team.
05-03-2024 10:58 AM
What makes you think this is a wider issue? The vast majority of "I've lost coverage" issues are caused by temporary single site outages. In rural locations there isn't always overlap with neighbouring sites.
05-03-2024 11:14 AM
I mean it isn't something just affecting my phone. I've already shown others have reported issues elsewhere.
05-03-2024 11:24 AM - edited 05-03-2024 12:06 PM
Site outages cause a loss of service to any phone normally served from that site if there's no overlapping coverage from other sites.
Independent "is my service working" websites are often extremely vague and their results can often be treated with a pinch of salt with anything other than widespread national issues.
