Re: How do i complain about poor signal?
OttoVonSkidmark
Had really good signal now it’s dropped to one bar and really slow internet. Never known it so bad.
Indicated bars are only a guide and one bar is still a bar - this should not cause any issues with making calls or sending texts.
You can report slow data speeds using "check status" on https://coverage.ee.co.uk/coverage/ee
