12-10-2022 06:29 PM
looking at cellmapper where I live, how do you know if they do 5G or not
12-10-2022 06:37 PM
Select 5G NR from the network-type drop-down
Remember this is a crowd-sourced map, so the data on there depends on other users in your locality recording and submitting data.
12-10-2022 07:41 PM
Cellmapper will only tell you if a 4G Mast is in the NR ENDC Layer, it will not tell you if the Mast is a 5G Mast or where the 5G Masts are located as EE use Multi Site 5G ENDC Regions on NR NSA.
Why do you need to know the 5G Mast locations, assume that's what info you are after in trying to use Cellmapper?
