Range warnings
kjee
Whenever my phone goes out of range or comes bank in I get a pestilentail warning beep!! This can happen 10 times in a 4mile drive!! How do I turn this off?
11 REPLIES 11
Leanne_T
Hi @kjee
Thanks for coming here.
Are you using an app when this happens?
Does the warning beep only occur when you're driving?
Leanne 🙂
Thanks. It happens when I have no app open, and of course only when I'm moving.
Leanne_T
Thanks @kjee
What device are you using?
Android 10, on a  Moto (g7) power. Fully updated.
Leanne_T
Thanks @kjee
Does any message show on the screen when you hear the warning beep?
I don't think so (I'm driving!) There is dropdown message saying signal dropped out, or came back.
Leanne_T
Thanks @kjee
Just to check, do you have Maps active at the time?
If this only happens when you are driving, could you try turning off notifications for any apps that may be active in the background to see if this helps?
Thanks. I don't think I had maps active this last time. How do I find backgound apps?
Leanne_T
Thanks @kjee
Please see the Managing notifications - moto g7| Motorola Support UK page for steps to check and also a chat option for Motorola if this continues to happen for you.
