Problems again in Freswick caithness
C70
No phone signal since early yesterday morning got a message from ee telling me there was a problem and that it would take a maximum 15hrs , last time it happened it took over a month that was on the 12th of Aug not very happy, checked mobile network coverage and it says it’s ok when it’s NOT!!
Northerner
Hi @C70
Can you access EE WiFi calling service?
The online status checker serves two functions.
1: "Check coverage" predicts the usual service in any given location - I suspect you're using this.
2: "Check status" searches for known faults & issues, with the subsequent options to "get updates" & "report a problem" as necessary.
Try using the check status option.
