10-12-2023 02:59 PM - edited 10-12-2023 03:40 PM
As of 09/12/2023, my MicroTik router is experiencing connection problems to 4G. It's been fine for well over a year previously.
This might have been happening a little longer than this, but I only really started looking into it in depth today.
4G connection only occasionally and even then only a few IP packets get through with huge ping timeouts then of 10-30seconds.
Doing a LTE scan I occasionally get this: (Evolved 3G LTE)
But mostly now just these:
My phone is working just fine on 4G and the signal is strong.
I've seen other posts from users having the same issue. EE have you rolled out a software update around the network recently that might be causing this?
12-12-2023 10:09 AM
Now resolved by updating both the routerOS to 7.12.1 and then also the modem firmware to MikroTik_CP_2.160.000_v021. This has to be done over LTE, which, given the lack of a stable LTE connection means using another providers SIM in the router to get the firmware update installed.
10-12-2023 02:52 PM
I am having the same issue as of this weekend.
But mostly now just this:
My phone is working just fine. Has anyone solved this yet?
10-12-2023 03:37 PM
Stuck on this now rather than LTE:
Same SIM works fine in my phone.
11-12-2023 08:12 AM
Hi @simona67,
I'd recommend reporting this issue to our Technical Support Team.
They'll be happy to look into it for you.
Thanks 🙂
12-12-2023 10:09 AM
13-12-2023 07:38 AM
What does it say under registration status?
I'm getting denied on 4G but on 3G it works but. Try hit and miss.
