on 25-05-2024 07:38 AM
I have really poor service to a point at times I cannot make/receive calls! This problem has only occurred over last couple weeks!
any suggestions! I should be on 5G but this changes!
on 25-05-2024 08:02 AM
@Jog123456 Is this in just one location or more than one location? In more than one locations point to a device issue, but you can check the network to see if there is a known issue in your location you can use THIS
on 25-05-2024 08:08 AM
on 25-05-2024 08:18 AM
@Jog123456 Have you tried a network reset on your device? This is in settings>general>transfer or reset iPhone>reset>reset network settings.
on 25-05-2024 08:51 PM
4G is generally regarded as the base coverage layer, does your phone fallback to that in the absence of 5G.
Testing whether this is location-specific or more general, will be fundamental to fault-finding.
