26-10-2023 08:35 AM
NO Signal or calls?? is the network down
26-10-2023 08:39 AM
Unless you're also using WiFi-calling, lack of network coverage would cause an inability to use calls or texts.
Assuming you've restarted your phone, this is likely a transient local outage. Use the "check status" option on https://coverage.ee.co.uk/coverage/ee
