No signal!! no calls no text HELP
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2024 10:11 AM
I was just on the phone to Ee upgrading then all of a sudden a complete outage , lost all signal and wifi, got home and getting internet but no wifi calling no signal help!!!
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2024 10:27 AM
If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker in the first instance, to check for local service outages. A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage. Home broadband uses different technology, and will be an unrelated issue - unless that's also with EE and there's an account issue.
