10-10-2025 09:35 AM
I have no service on my phone, cannot use the internet or my phone..
10-10-2025 10:58 AM
@GulbaharDonmez1 : If it is a neighbourhood issue, you could consult Check service in your area to see if any faults are being attended to in your local area.
10-10-2025 11:07 AM
If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker r in the first instance, to check for local service outages. The "report a problem" link should be used if no issues are reported but EE users continue to have issues.A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
