No phone signal in denver norfolk
hateful1964
Is this a recent problem? You can check for known faults using "check status" on the coverage tool linked below. That allows you to then "get updates" or "Report a problem" as appropriate
https://coverage.ee.co.uk/coverage/ee
thanks man, these idiots tell you nowt
Use the "My places" option on the same tool to register upto 5 UK locations for proactive updates.
