No phone signal in Castle Donington
graham1973
Anybody else having problems getting phone signal in Castle Donington ?
Rach_H
Hi @graham1973,
It's great to hear this is working again for you now.
Rach
15 REPLIES 15
@graham1973  Have a look at THIS  and click the check service status tab to see if there’s a known issue in that area.  You can report an issue also.
graham1973
Tried that and no known issues
@graham1973  Have you tried restarting the device?  Did you report an issue?
I tried three different phones with no signal and i have sort of reported the issue but as it is my Mother inlaws address, i think i have reported my address
JEM5817
Been down since Mon. Why? Really annoying.
So i am not the only one, and it is a fault with EE ?
Can only assume it is a mast issue! Seems to be no fault info available.
ok thank you
Rach_H
Hi @graham1973,
Welcome to the Community!
When you log into your account to check the status you can scroll further down the page to check another area. Do you know if you did this when you were reporting this outage?
Rach
