Network
shabbir66
my 4g is low when I am outside in London. How do resolve this?
@shabbir66   What do you mean by low ?  Can you connect to the internet?  Do your apps that need cellular data work ?
354-
Star Contributor
Star Contributor
Have you had a chance to check your current location's EE coverage? https://coverage.ee.co.uk/coverage/ee
Are you able to make use of WiFi Coverage Boost? https://ee.co.uk/help/help-new/network-and-coverage/coverage-and-speed/how-do-i-access-wifi-coverage...
Are you visiting the UK? Have you tried manually selecting EE as the roaming provider on your device?
Putting perceived coverage aside, are you having any problems using your phone outside in London - and if so, what are they?
