Network status check if you're not an EE customer
John_yorks
So how do you do a network status check if you're not an EE customer, there's 5 or 6 networks that use EE
(I'm with slice mobile) And can't check the local network status,
with other networks (o2 and 3)
You can just put your postcode in without registering, why can't you do that with EE
[mod edit: edited for tone]
@John_yorks wrote:
So how the hell do you do a network status check if you're not an EE customer, there's 5 or 6 networks that use EE
If you are with an MVNO provider, then your point of contact for any service issue is that MVNO provider.
EE have intentionally locked status checks to direct customers, which if you're with an MVNO, you're not.
I'm guessing that with other mvno's that use EE 'signal you wouldn't be able to check the network status either,
Seems a bit ridiculous really
I don't know of any MVNO who provide access to EE's fault-check tools. You need to consider this just as much part of your purchasing decisions as any other aspect of MVNO service.
@John_yorks  EE is not your network provider any issues you face you need to report to your provider.   EE don’t have to provide any service tools for none EE customers.
